Pro96Com Enhancement?
greenthumb
Colorado DB Administrator
Is there a chance that we can get the manufacturer of the system to display in Pro96Com, maybe in the site information tab where the CW ID, etc. are? The Manufacturer ID is broadcast regularly on the control channel of a P25 system.
Manufacturer ID / Manufacturer
$10 / Relm/BK Radio
$20 / Cycomm
$28 / Efratom Time and Frequency Products, Inc.
$30 / Com-Net Ericsson
$38 / Datron
$40 / Icom
$48 / Garmin
$50 / GTE
$55 / IFR Systems
$60 / GEC-Marconi
$68 / Kenwood Communications
$70 / Glenayre Electronics
$74 / Japan Radio Co.
$78 / Kokusai
$7C / Maxon
$80 / Midland
$86 / Daniels Electronics Ltd.
$90 / Motorola
$A0 / Thales
$A4 / M/A-COM
$B0 / Raytheon
$C0 / SEA
$C8 / Securicor
$D0 / ADI
$D8 / Tait Electronics
$E0 / Teletec
$F0 / Transcrypt International
mikey60
Oakland County Michigan
99% of the data transmitted on the control channel is MFGR Code $00.
The only time a manufacturer code is transmitted that I've seen is the case where there's a non-standard control channel message that uses a manufacturer specific message.
Mike
mikey60
Not all is 00 ;)
The new 380 system 0157 in Los Angeles uses a Mfg code of 90
09 90 0B 40 00 00 00 00 00 00 3D FE 04/12 15:08:55 Unknown Op=09 Mfg: 90
Ok, so there's a Motorola defined packet. (And if anyone knows what that particular packet type means I'd love to hear it). Tell me exactly why I should take this as the system is a Motorola system? The Mfg code only means that this is an extension to the protocol that Motorola added, it doesn't mean that another manufacturer won't use it as well if they have the need.
Patches are another area that use Mfg 0x90 type packets, but other manufacturers also use those, so there's no guarantee that it's a Motorola system, simply because these packets exist on the system.
Mike
WayneH
Forums Veteran
Super Moderator
Sitting in an airport somewhere
Just identifying the code's manufacturer would be nice. Doesn't necessarily need to identify the system but a small bit of text identifying who it is would be helpful.
Saves time on looking it up.
mikey60
This is done for the next release. The CC dump data will contain the Mfg ID for any non-standard packets, and unknown packets should also be tagged with the Mfg Name
Mike
