Pro96Com Restore Hit Count Display
N9JIG
Sheriff
Moderator
Far NW Valley
Somehow I seem to have changed something and the channel hit counts no longer display on the Site Activity window on one of my occurrences of Pro96Com.
I cannot seem to find where to turn this back on.
It is working fine on another occurrence running on the same computer on a different site of the same system.
Any ideas?
mikey60
Oakland County Michigan
I responded in the Pro96Com Yahoo group, but here it is again.
Stop that instance of Pro96Com and close the program. Locate the Pro96Com.ini file for that instance, and then look for the Column10 entry under the [ActivityScreen] section. The default value for that is 50. Restart the program and the column should appear..
Mike
N9JIG
Sheriff
Moderator
Far NW Valley
Thanks Mike. I checekd the .ini file and it had 50 as that value.
I ended up replacing the .ini file from another instance and that seemed to work.
Question for you? Does the program read the .ini file in the same directory as the application or another location?
