Can't seem to get it to work with my unit,saw on one of the threads I believe there is a setting on the unit to be set any help would be appreciated,works fine on my 800?
Perhaps obvious but you need a good quality CC signal (I assume you have that) and you should HOLD on a lightly/unused talkgroup (or create a dummy TGID like 9999 to HOLD on).
Having said that - what is Pro96Com doing/saying (or not) when you try to run it against the TRX-1 signal/feed?
You said it works fine on your PSR800 -- same system/control channel?
