Problem decoding Edacs system using Unitrunker
jo152
Sherbrooke, Quebec
Hello
I'm having problem decoding an Edacs system, this one: RSP Sherbrooke Trunking System, Sherbrooke, Quebec - Scanner Frequencies. I have attached a picture. As you can see, the control signal is working but the channels' frequencies are 0.000 so I'm not getting any voice signal output (at least, I think that's why). I've seen in a tutorial about a calculator/wizard button that could solve this issue but I don't have it so I guess it doesn't apply to this type of signal ? Anyway, if anyone could help, that would be very much appreciated. I'm somewhat a newbie with trunked channels so if I forgot to provide any information, please tell me.
Thank you !
The calculator tool is for Motorola systems. For EDACS, you must provide the frequencies.
Go to the Channels tab, press "F2" for edit mode, move the cursor to the frequency field and enter the frequency for each channel that needs one. Press "F2" again to leave edit mode.
