Problem keyloading EF Johnson 5100 ???
kotaguchi
Northern Mi
Ok.
I sent off a pair of EF Johnson 5100 Model 2 W/AES encryption so my buddy can key load the radios for me.
He tried keyloading the radios using his Motorola KVL3000+ with a Motorola XTS KVL cable.
Every time he tries to keyload the radios,he get a KEYLOAD FAIL.
The radios are both model #242-5126-460-GZ4.
firmware:4.4.16
Is there a special mode in the software programming screen for this or does the EF Johnson uses a different KVL cable?
Thanks in advance.
Ko
grem467
Houston, TX
the cable is different. There is a mod floating around the net on how to mod a moto cable to keyload.
hitechRadio
Yes, Grem is correct, it is a differnt cable, looks the same. The part number from ef-johnson is,
585-5000-932
kotaguchi
Northern Mi
Thanks for the replies.Anyone know about how much does the KVL cable from the EF Johnson is going to cost?
mancow
N.E. Kansas
I will have to look for my diagram. From what I recall the cable had an extra ground that shorted an extra side connector line to initiate keyload mode.
wlmr
Used to be that a cable modified for the Johnson would still do Motorola. Anyone know if that is still true? That would keep you from having to buy another cable, just modify the Motorola one.
