Problem on Will Co. EDACS
TrenchFeeder
TrenchFeeder
I know you guys are probly getting sick of my problems, but I'm not getting a control tone on the Will Co. EDACS. I rechecked the frequencies all programmed in correctly.
I'm leaning towards it being a problem with my scanner, because when i hit the manual button it goes to bank 0 channels, and I have the EDACS programmed in bank 1. Usually when I hit manual while I'm scanning the EDACS it drops into bank 1 on the control tone.
I just wanted to put it out there and see if anyone else was having the same issue, before I run out and buy a new scanner
TrenchFeeder
TrenchFeeder
After I put 2 and 2 together I realize it's obviously my scanner. The past few days I was hearing what could only be described as a slide whistle on all different freqs.
Oh well, it's about time for a digital unit anyway
R.I.P Pro-164, 4 years of great listening
RoninJoliet
ILL
If on my RS2096 i am listening to Will Co in bank 2 and press manual it normally goes to the CC... I have heard some what sounded like the noise you described tho yesterday...They were testing what they called "Open Sky" radios on TG 10-065 (1333) -Det1-EMA vs EDACS brand radios??....U sure you had the county "bank" turned on when you pressed manual??....
RoninJoliet
ILL
PS: Forgot, just my opinion but if you replace the scanner with a new H/H my personal preference is the Uniden 396XT with the NEW firmware 1.10 that helps hear the STARCOM multisite systems better and decodes digital very well...If its a base i have very good luck with the Uniden996XT and RS197 Digital base usually on sale for $350.00
TrenchFeeder
TrenchFeeder
Thanks for the info.
I been looking to get my current one repaired. Something is wrong with the antenna. When I put it on signal stalker it doesn't scan, it just sits on one channel. On normal channels I just get little skips of static when it's receiving. Radio Shack was no help, they told me they don't do repairs and couldn't direct me to anyone that does
TrenchFeeder
TrenchFeeder
Yeah, I only had the Will Co. bank active. I heard the "slide whistle" on Will Co., Shorewood, Joliet, Tinley and Olympia Fields.
It's definately something with the scanner because today I'm not getting anything on any channels. When I was manually listening to the EDACS I wasn't getting a control tone at all. I opened the scanner up and nothing LOOKED broken, so I'm guessing it's software related, if not that then some connection in the actual circuit board
RoninJoliet
ILL
Do u get the WX, if not it may be a break in the antenna connection inside as some have written....Inside where the BNC weld is located, just a guess from what i read....
TrenchFeeder
TrenchFeeder
No weather doesn't work either. Same as on signal stalker I can't change channels on it either. I can't get at the connector because it's inside a metal cover that's soldered to the circuit board. There's a nut holding it on but it's almost flush with the board so I can't unscrew it
RoninJoliet
ILL
RadioShack does have repair centers, should try another RS, try to find the "district store" where the district manager can be contacted...May not be worth the price to repair....Im hearing "Wescom" dispatch Elwood over Will Co Edacs on TG04-083, i know there going to Wescom instead of Will Co but i do not hear them on any simulcast VHF freqy like 158.85.....
gooniorjr
35mi South of Chicago......
