Yes BC_VUP v2.0.0.7 is the correct one, and you need to register your product in order to download firmware from Uniden, From your msg, I think you have obtained it, so try this file againI think I loaded wrong file or update
Not all cables are created equal. I had trouble with Prolific and no trouble with FTDI on win7,. Another thought would be to check ports as described :Connecting scanners via USB - The RadioReference Wiki, but it does sound like you are connecting properlyit came with a cable---usb to serial-----I have tried it 100 times at least----gets to end and stops with error
