n5gqb
Just got my G5 back from having the dmr upgrade. For starters I programmed in one of our local amateur 440mhz dmr repeater. After reading a few threads on how to program the dmr stuff, I got all the parameters set. I sent the program to the radio, went fine, no errors or such. I tune to the zone/channel where this repeater was. However all the received signals were garbled, even though I was in good range of the repeater and my TYT & SDS-100 was receiving the signals just fine. I had one channel set with Time Slot 1 and another for Time Slot 2. I was using the wildcard FFFCDF/16776415 to be able to receive all talkgroups. Many folks have commented this # works and their radios receive fine. My garbled transmissions were 100% always garbled, all transmissions, no clear spots. For those who know the sound, it sounds kinda like when listening to a p25 encrypted talkgroup (all garbled) with a scanner that will pass the audio through on such. It does not sound like a weak signal garbling. Any ideas?
Model # g5b67bf-sxucen1401
PPS ver 0.3.14.15
Tab 2 -Freq entered as conv 12.5 bandwidth, signal activity timeout default 600ms
Tab 3 created 2 dmr protocol's TS1 & TS2
Tab 4 created 1 dmr talkgroup with wildcard
Tab 5 Selected monitor mode, then selected the repeater freq in the "conv freq" drop down. Set protocol to dmr and alias to proper TS. Color code to correct #. Checked repeater mode box. Enabled the wildcard talkgroup at the bottom of page. Everything else in Tab 5 was default, then sent to radio.
I have not (yet) created some individual talkgroups to try that. I have not tried any other tier 2 repeaters or systems.
FWIW-all p25 and fm stuff is received fine.
Thanks, Sly n5gqb
PPS ver 0.3.14.15
Thanks, Sly n5gqb
