problem reception bct15x up 39 mhz
ubc
i have a probleme with my bct15x : i have no reception up 39 mhz
no reception vhf /uhf
what is the solution to repair this probleme.
thanks you very much for helps
f5nts bertrand
jonwienke
More Info Coming Soon!
VA
Send it to Uniden for repair?
Get a different antenna?
ubc
the antenna is good because i have annother bct15x it's receive on.
i wand repaiy himslef because it's very expansif the send bct15 to uniden .
jonwienke
VA
Sorry, we can't troubleshoot your problem for you over the internet and tell you which transistor or whatever to replace. There is no magic bullet repair that always fixes the problem. If you don't have the skills to troubleshoot the problem yourself, sending the scanner to Uniden or finding a local repair shop are your only options.
JamesO
McLean, VA
I have seen this problem on the BCT15x and the 996xt where something shorts/fails in the units and they seem to receive fine in the VHF low band, but FM broadcast and above do not work properly.
Seems to be an issue either with a mixer stage and/or preselector/input filter selection?
I do not think the problem is with the front end amplifier(s).
