Problem scanning Hinds county System
Rick54
Mississippi
I have had a 785D with digi card for over 2 years and I have had this problem since day 1.
Everything works fine until the system switches to 866.850. when the transmission is complete the scanner hangs there and it sounds like a birdie just dead carrier and wont resume scan unless you press the rsm button.
What ever this signal is, it is coming from the jackson area, if I get out in the rual areas the unknown signal gets weak and the scanner works ok.
Has anyone had this problem?????????
INDY72
Indianapolis, IN
Check the database for other systems using this freq..... I run a PRO-92 B on the HCTRS for the EOC/VFD TG's and NEVER have had any issues.
Rick54
Mississippi
I also have an old RS 800 scanner and I put the 866.850 in it and I also hear the signal on it???????
