I had something messed up with a scan list. When I was on a mode w/o scan on it worked fine (it an rx only mode). When I turned scan on the radio shut off. This happened with other modes with the same scanlist. I never enabled scan while on the modes. Now when the radio turns on it will not get past the self test. It shuts off right away cause it power up on a mode with the bad scan list and scan is enabled.
Is there a way that I can reset the radio or get it to power up on the home mode so it will stop cycling on and off?
