I am trying to monitor a new trunked VHF P25 system locally, using 152 Mhz. outputs and 157 Mhz. inputs.
I have been unsuccessful tracking this system using P25 AUTO or P25 MANUAL with the DEFAULT T-Table. Programming these channels as conventional P25 channels works fine, but no trunk tracking of course.
So I assume I need to create a CUSTOM T-Table for this system.
While trying to create this T-Table, I have found several problems with the BuTel ARC 500 Pro software, and I am curious if anyone else is having these issues.
1.) The software will not allow me to enter the correct base frequency information in the CUSTOM T-Table, it keeps defaulting to 851.000 or 512.000
2.) If I enter the correct base frequencies via the scanner keypad, then download the radio info using the BuTel software, the software correctly displays the information I entered, but when I save the file, then reopen the file OR upload the file back to the radio, the base frequencies are back to 851.000 and 512.000 !!! This means every time I use the BuTel software to change programming, typically several times a day, I will need to re-enter the T-Table information for all the CUSTOM T-Table systems by hand, each time.
3. The BuTel software gives you the T-Table choices of DEFAULT, CUSTOM, or SPLINTER. The problem is the radio does not have a 'SPLINTER' choice in it's firmware, and the BuTel software keeps defaulting to Splinter when I choose custom, enter the info, and save the file.
For your reference, the desired P25 Control Channel data as decoded by the PRO96.com software is:
ID -00 / S-1 / BASE FREQUENCY - 851.00625 / SPACING - 0.00625 / TX OFFSET - -45.00 / A/C - A / BANDWIDTH - 0.00625
ID - 01 / S-1 / BASE FREQUENCY - 762.00625 / SPACING 0.00625 / TX OFFSET - 30.00000 / A/C - A / BANDWIDTH - 0.00625
If you try creating a CUSTOM T-Table with these base frequencies in ARC 500 Pro, you will see the problems.
Also, the Scan List Preview tab does not work for Favorites or Skywarn lists.
Is there anything I can do, or do I need to purchase Win500 software?
