Problem with drop and drag using CPS
18bravo
Lake Whales
I have two XTS5K's, I had to use the drop and drag method due to minimal different features. The radio that I dropped and dragged is not picking up all the transmissions like the original radio. Any help for a possible fix would be greatly appreciate.
a417
did you compare the two codeplugs to verify?
wgbecks
NE Wisconsin
By any chance, do either or both of your XTS5K codeplugs have expanded scan lists?
wgbecks
NE Wisconsin
I'm only scanning one zone 10 channels.
Is your XTS configured for NAS on a P25 System? If so, look at the Trunk System programming in the doner (original) radio to see if the parameters are identical in the radio that received the Drag & Drop operation. Pay attention to band plan and coverage type.
clbsquared
Isle of Wight County
Also, your system keys need to be loaded in both the donor codeplug and the receiving codeplug.
18bravo
Lake Whales
everything looks good
wgbecks
NE Wisconsin
Not much information to go on here. Are both radios on the same FW version? Have you tried manually programming any of the TG's in the second radio to determine if that makes any difference? What is the P25 system? it might be that parameters that seem to work in the doner may not be exactly correct for the second radio if there FW versions are radically different.
It was mentioned early on to check alignment. I would recommend running Tuner to at least verify that the reference oscillator frequency is withing tolerances. Depending upon what frequency band, there may be other alignment points applicable to the receiver that also need to be checked.
18bravo
Lake Whales
After watching the radio more I noticed that the radio is stopping on the talk group just no audio is coming out or it's missing the first second or so of the transmission. Also this radio has worked fine on another P25 system before. I have double check the settings several times from the drop and drag and everything has looked fine.
