Problem with last TX update??
RadioBoy69
Ft Worth, Texas
Was/is there a problem with the last database update? After i performed the update, the Ft Worth RRS, and Plano system did not work. on my 496 I messed around with it for two days trying to fix it and had to program it with an older database to make it work again.
Anyone else have that issue before?
BenScan
D/FW
Sorry, I misunderstood the message originally.
hiegtx
Dallas, TX
I have not been having problems with either system. In fact, over the last couple of days, the Plano system, PAWM, has been coming in with better signal strength than usual. Since I'm in Dallas, southwest of downtown, I have to use an external antenna.
I created a "test" Favorites list, based on this week's database, with just these two systems. So far, no difference (in reception) between it and the ones "saved" in my normal working Favorites list.
If you previously had either (or both) of these systems set with a different P25 threshold (at the site level), but deleted them, and appended the ones from this weeks 'updated' database, this could be the cause of your problem, as it would have defaulted back to Auto.
