jmanct18 said:
I am having problems setting up East Windsors LTR system . Can any one tell me step by step and help me out. I cant get it to work.
Thanks a lot
Joe
According to the manual, the pro 91 does not do ltr trunking. Heres a fax back document
PRO-91 150-Channel Handheld Trunking Scanner
(200-0521) Trunk Tracking Faxback Doc. # 48461
Your scanner is designed to track transmissions on Motorola Type I, Type
ll, and hybrid analog trunking systems, which are extensively used in 800
MHz communications. Remember these important points when tracking
transmissions:
Your scanner monitors Type II systems by default. However you can
change this if the system in your area is different (see "Types of
Trunking Systems" below and "Scanning Type I and Hybrid Trunked Systems"
below for more information).
Your scanner cannot track transmissions on non-Motorola trunking
systems.
Your scanner cannot track an 800 MHz trunked system and scan
conventional frequencies at the same time.
wesct
