nexus
I recently bought a PRO-95 and the other day I finally broke down and bought the radio shack PCIF cable. Downloaded WIN95 and began to create from a new template...
I made bank 0 as a Motorola and put in a motorola II TRS, and on bank 1 I made it EDACS and put in an EDACS TRS, and filled up about 2 sublists full of TGID's.
Here's the thing. At first I used DEC like 0673 instead of AFS... I uploaded everything I saved into the scanner...
First thing I noticed was that nothing was set to either mode mot or ed.. I had to manually go behind win95 and push the mode button on each memory channel depending on if it was ed or mot. Then I noticed some memory channels were LOCKED OUT in the scanner but in WIN95 none of the channels were ever locked out.
Back to the talkgroup issue. I don't know if this is just win95 or the scanner itself. I changed my mind and decided to use AFS. So I changed all of the talkgroups for bank 1 to AFS saved it and uploaded to scanner. Now I can't hear ANYTHING in closed mode. If I go to OPEN mode it'll stop on activity but none of the text id's I assigned are coming up. Only the AFS like 05-041. So I changed everything back to DEC, saved, uploaded it again..
Ok this seemed to work. I'm now back in closed mode and I can hear active talkgroups and I'm seeing my text ID's. So any idea what's going on????
