an39511
I just received back two radios with the repaired headphone jacks. That problem is fixed but I have discovered a possible problem with the USB jack on both radios.
I did not notice this on the radios that I original returned for repair however they may have exhibited the problem but I just didn't notice it.
Here is what I have done to test this;
Using Windows 7 open up the device manager.
I am specifically interested watching the Ports (COM & LPT) devices.
When I plug the USB cable into the radio I receive the standard prompt to select Serial or Mass Storage. I select Serial and watch for the device manager to show the COM port. Sometimes it shows and sometimes it doesn't. If I jiggle the USB connector at the radio head the device manager will intermittently show the COM port as being there and a moment later it is gone. If I wiggle the plug just right the COM port shows up and stays connected.
I have tried both cables supplied from Uniden and two other USB cables known to be working properly. All four cables exhibit this problem on both radios.
At this point it does not seem to affect USB Mass storage, only the serial connection.
Here is a link to a video that clearly demonstrates the problem;
UnidenBCD536HP Serial Port Problem - YouTube
I just noticed this thread may be better off in Uniden Owner Tech Support. If you want to move it that is OK by me.
