XTS3000 Problem with XTS3000 III Motorola
MixROx
I bought a Motorola XTS3000 two weeks ago from ebay, it arrived today and it is not programmed, it is normal that when the radio is not programmed when you accept it the green LED stays on and the screen is not seen and nothing happens?
- Andrea
Ant9270
The Green Weenie
- Andrea
It could be possible that when the radio was wiped, the technician removed the zone/channel name leaving a blank screen. If you’ve already verified that isn’t the issue, it sounds like the LCD or flex cable went, which is a common problem with these older XTS3000s. Try turning on the radio, and clicking the 2nd side button 5x to put it into service mode. If nothing displays, the LCD is toast.
MixROx
I think the problem was that to be shipped the battery had to be completely discharged, in fact now the screen is on I already have the astro program, to program it is mandatory or can it be done from the radio?
mbnv992
AZ
Sounds like the OP has no idea what they are doing. Get your money back for the ( more then likely inhibited ) XTS and get a scanner. Or some frs bubble pack radios and call it a day.
