Problems programming Icom IC-F121S
LA9JDA
Bodø, Norway
Have problems to program ic-f121s. I am using Cloning software IC-F100 ver. 1.7.
I get a message that says "No answer from Transceiver. Tried to program another IC-F121 and it worked ok.
Any hints? How reset the trcv?
tnx paul
LA9JDA
mjthomas59
I'm not sure if this is the issue or not. But you said you were trying to program a f121s with no luck. But you were able to program a F121 and it worked. The software is different for these radios. Not sure if that is the problem you are having or if you just had a typo in your initial post.
The correct software for the f121/f221 is CS-F100
The correct software for the f121s/221s is CS-F100s
v1.7 is the latest for software cs-f100
I don't recall the latest software version for the "S" version radios
Most radio software is available on fleabay. Here is a link to one that I found with a quick search: http://cgi.ebay.com/ICOM-CS-F100S-S...72428?pt=2_Way_Radios_FRS&hash=item2eb3488ecc
tealc_07
Abilene Texas
Does anyone know if I can download Icom IC F100 v 1.7?
I found v 1.3 but when I try to write to the radio (f121) it says, "Update Software".
I got the software with the USB cable, but I lost the disk and don't want to buy the program again.
bikinjohn
Las Vegas, NV
Wirelessly posted (Mozilla/5.0 (Linux; U; Android 2.3.3; en-us; DROIDX Build/4.5.1_57_DX5-35) AppleWebKit/533.1 (KHTML, like Gecko) Version/4.0 Mobile Safari/533.1)
Will your software program a FC221-1?
R
radioanswer
Guest
tnx paul
LA9JDA
Hi Paul,
You need Software Rev 1.6 for F121S , 8 channel radio model.
The version you had is for F121, 128 channel model
Let me know if you need more help.
HP
