needhelp
Hi, I hope I can get some help for my BCD396T Handheld Scanner problem. I am not able to use some frequencies and when the`scanner picks up voice it is very hard to understand or recognize what is said and a "ENC" is displayed under the frequency.The frequency is in the range of 467.0000mhz through to 469.4000mhz. I am able to get FM radio and TV very clearly and have recently turned off the Broadcast setting after reading that it could be a problem and effecting the other frequencies. Turning off broadcast did not fix the problem. The scanner has 27% memory used and the firmware version is 1.13.03. Does any one else have or had this problem? I am not a wizz and would be very great-full if any help given in a easy to follow way. Thanks Danny
