daves
I am new to the "Trunking" part of scanning - and I could use some advice. I read the post on FAQ for Uniden and the set up is similar to the PRO 94 - but there are differences. For example I don't think the off set spacing is included in my Pro 94.
In any event, I am north of Lindsay and will be monitering Lindsay, Fenelon Falls, Haliburton Peterborough OPP.
I have programmed the Base Frequency, offset but not ofset spacing. I have inputted the frequencies for Peterbrough, Haliburton and Fenlon from the Frequency list as regualr scan frequencies with DATA code to silence out data bursts.
When is trunk scan mode I get hits of 8304 and an associated frequency
of 142.980 and 8832 - 142.455 so I have inputed these two ID,s into the trunk scan bank.
However, I will only get the scanner to stop on one of these two ID's with data bursts---but never any voice while stopped in the trunk scanning mode.
Do I need to input ALL of the system frequencies including black, red and blue for all the detatchments as normal scan frequencies?? or will the three detatcments I have put in be enough? Any info on "Lindsay"?
Is there something I am missing here?? Is perhaps the Pro 94 not OPP receivable??
