I am working to program a Uniden BC 796D. The unit is located in the Winston Salem, NC area. I have normal frequencies programmed into the unit fine and working. However I am trying to use bank 10 to add the Forsyth County Motorola trunked system and I cannot get it to work. The unit does show on the screen MOT ID and cycles through I CALL ID numbers, so it seems to be getting that information from somewhere. However I am not getting audio through the unit, just static as those numbers go through the screen. I have been using the advanced radio control software to program the unit. Thank you for any help at all.
The frequencies I have been trying to program are listed here. http://www.radioreference.com/apps/db/?sid=1682
I have also included two screen shots of the setup from the advanced radio control program showing my settings.
