XPR Procedure for FW upgrade on XPR3500e
flsdan
what is the procedure for upgrading the firmware on a xpr3500e.
I have the down load and want change from ver 2.09 to 2.0 and code plug fron ver 14 to ver 15
Tech21
You want to go from 2.09 two 2.10?
You will need CPS 2.0. Once you have that, you go into CPS 2.0, and click update from the tool bar.
flsdan
I'm unable to clone the radio between the two versions.
When I try I get a code plug version mismatch alert.
It would also be an oddball radio in the mix for the customer.
I appreciate the quick responses thank you guys
chrismol1
P25 TruCking!
There is a consensus that upgrading beyond CPS 16 2.09 is bad because its becomes difficult for casual users. 2.09 is now 2 years old. The world has moved on and new radios & existing customers of real business needs need to upgrade as in your case
K2NEC
