Professional Radio CPS 6.12 channel cloning
FoxMcCloud
I have two HT1250's, one has got all my frequencies on it but the other does not, and I'd prefer not to have to type in the same 80 channels again. Is it possible to copy over the conventional personalities effortlessly and not monotonously from one code plug to another?
Yes, but ONLY if the two radios have the exact same model number. You can simply read the file out of one radio and write it into the other.
FoxMcCloud
Well ****, off by one number, they are as following
H25RDH9DP6 (This one has a keypad)
H25RDH9DP5 (This one has limited keypad)
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
What mmckenna said.
Unfortunately, with the Pro Series CPS there is no drag and drop or copy and paste. If the model numbers are not an exact match, you’re stuck with building the entire codeplug each time with no shortcuts. It’s known weakness of this software.
FoxMcCloud
Wow that's bull. I think even the Astro CPS lets you drag and drop. Too bad I guess, I'll find a way to make it less painful
Yeah, true, but this CPS isn't a whole lot newer than the older DOS based RSS. There's a lot to be desired.
And for most commercial users, they are buying tens/hundreds of identical radios, so being able to swap files between different models isn's something that's needed.
Firebuff66
CT
If you open a channel, on the very bottom of the conventional personality the far right icon changes it to a spread sheet type of view. With control C and Control V you can cut and paste the alias, RX & TX freqs BUT right after you cut and paste you have to click on each (alias,RX & TX) of those individuality to have the program accept it and you can do only 1 row at a time...Its clunky but if you have 200 channels it helps A LOT
Or you can use the special software and just make them both the same model
