Professional Series 25khz Entitlement
rkumetz
I have a pile of CDM1250's and HT1250's that I maintain which have 25khz because of mutual aid to Canada.
Old story - New laptop = headaches.
It appears that Motorola is holding their breath and saying sorry Charlie that software is no longer supported.
Anyone know a way around this whether it is some relatively unknown official channel to obtain the code or
some way to trick the RSS into thinking it has the entitlement?
My head is going to explode.
rkumetz
I was trying to delude myself into thinking there was an easier way. I already started a case but that should take a few days.
rkumetz
I suspect if you google w9cr and waris you will find a link for 6.12.05 which will work fine and last version before wideband BS.
I will give that a try. I own the software so I may have that zipped up somewhere. Will I run into the problem of having a radio that was last programmed with a later version than that?
rkumetz
6.12.05 solved the problem.
Anyone happen to remember if it is possible to get a CDM to power up on either a specific zone/channel or Z1 CH1?
I seem to have a problem with people changing the channel and turning it off but then the next person who uses it
doesn't bother to look what channel it is on. It simply needs to come up on the main dispatch channel every time.
At one point I am sure I knew this but as has been pointed out, these radios are pretty old. :)
