BCD536HP: Profile
N1XDS
ÆS Ø
Under edit profile in Sentinel how do I search Federal 150 to 170 and 403 to 430 band? When I click on the right settings then upload to my 536hp scanner it scans 450 band?
N1XDS
ÆS Ø
Anyone? I know there is a way in Sentinel to scan the federal frequencies under edit profile but not sure what area I need to select under edit profile.
ofd8001
Louisville, KY
You could try the following (I just tried it and it works, though there may be a less cumbersome way):
Open Sentinel and Edit the Profile
Go to the Custom Search tab
Change any of the Custom Search rows to the desired lower and upper search limit, noting the Custom number (which will be Custom 0 to Custom 9 - I used Custom 6).
Go to the Search/Close Call tab
In the Search Key box, change Search Key 1 to be Custom 6
Save the changes to the Profile and write the Profile to the scanner
Begin scanning and press Channel to Hold on a channel
Press Function then 1 to begin searching on Search Key 1
When finished Searching pressFunction+System to resume scanning
You can only do one range at a time, such as 150-170 and when its searching that range, you'll hear everything, not just Federal.
If you want a second range, such as 403-430, you'll have to change a second Custom Search row and assign that to a second Search Key
hiegtx
Dallas, TX
In the Profile Editor, you can select the Custom Search Tab.
Edit one of those preset searches to change it to the frequency range you want (150 to 170MHz). Then edit a second one for 403 to 430MHz. Note that you can change the names, if you want, to Federal Vhf Search & Federal Uhf Search. (This is basically the same as what ofd001 suggested.)
Now, click on the Scan Selection tab.
Select the Monitor Search with Scan
Click on Options
Set all of the custom search ranges to Avoid except the two you want to use.
Write that to the scanner. That would let you do both at one time.
