program a low band motorola radio
s1scanner
Guthrie OK
Hello I have a Motorola low band radio Maratrac 110watt trunk mount radio and i was wondering if there was someone who could program it for me if i mailed it to them. its the 42-50mhz i have the freq that i need put in it as well as the tx rx and pl tones. thanks in advance
cg
Connecticut
You should have a radio shop that is local to you. Just be prepared to show that you have permission to use the frequencies that are to be set for transmit.
A quick search shows one in Seminole, OK
chris
WX5JCH
Banned
Elk City, Oklahoma
Yes, OHP won't like it if you transmit on their frequencies
Bruce42
California
Low Band Programming
If he is in OK I doubt very much he could have an influence on CHP. Skip hasn't been that good. But spending the money to have the radio programmed means that thought should be given to the scan lists for each channel in advance so he wouldn't have to build a scan list everytime he changed channels. Or pay for more programming.
When listening to the CHP with my Maxtrac I programmed the scan lists so I would scan the channel ahead of me and behind me when set to a particular district so I had awareness of traffic conditions and resolutions as I traveled across the state. When I reversed direction I still had the next channel and the previous channel being scanned. I miss that with my Kenwood for it does not have individual scan lists per channel but at least it has an alphanumeric display so I know what I am tuned to without having to memorize so many numbers.
Have fun.........
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Have fun.........
The man referred to OHP not CHP. The gent who wants his radio programmed is in Oklahoma, not California.
