flafiretwo said:
Just finished updating my 780 XLT frequencies using the Barghis 780XLT Software. Connected the BCT 8 to the computer using same cable and program. Set BCT8 to PC@19200. Asked 780 program to load from scanner and ALL 250 Frequencies loaded. Program showed it read from a BC245 scanner. It appears I could make changes and send to scanner. However, I DID NOT try to load program to scanner yet. Thought I would ask for further information here before I went any further.
The protocol for the 3 scanners (8, 245 and 780) appears to be the same. (I didn't do a line-by-line comparison, but I needed some things for the streaming program I'm writing, so I went through the various protocol documents), and they're all banked, not dynamic memory so, aside from the differences in serial port speed, the program should work - with one caveat:
Are the banks set up the same on all 3? If you read a frequency from a bank that doesn't exist, or write a frequency to it, no telling what will happen. I doubt that the scanner will be damaged, but you may end up having to reset it to get the CPU back from the middle of next year.
