Program HAFB in PSR-500?
kf7yn
West Jordan, UT
I can't get my PSR-500 to scan HAFB.
My Pro-96 and Trunker scan HAFB fine using 406.1625 base, 381 offset and 12.5 kHz spacing, so it must be a matter of setting the custom trunk table right in the PSR-500 but I don't know the Low and Hi freqs. Does anyone have the proper custom trunk table?
shadowerr
Clinton, UT
Hi Jon,
The RR database says we should be using base of 406.500 with 12.5 spacing and 408 offset.
Thats what I have programmed into my 96 and seems to work fine.
-Mike
kf7yn
West Jordan, UT
The PSR-500 custom trunk table needs channel Lo and channel Hi. I just tried 381 channel low and 759 channel Hi and it is working so far.
jjwhite29
Philipsburg, Montana
I know I have a hard time getting a good signal from HAFB. And I still can't get Tooele Army Depot to work on my PSR 500.
kf7yn
West Jordan, UT
Try this custom trunking table in your PSR-500 for Tooele Army Depot:
380 channel Low; 759 channel Hi
Base 406.0
Offset: 380
Step: 25 kHz
Let me know if that works
jjwhite29
Okay i will try that but why when I run a frequency search I get 409.5500 as a CC and sometimes I get the other one.
kf7yn
West Jordan, UT
Because 409.5500 is the main CC and 407.9500 is the alternate CC. They switch back and forth now and then.
N7YUO
Kearns, UT
HAFB UHF Trunking.
From Mike Smith N7YUO
I am employed at Hill AFB. In June, I travel to Hill AFB Range, aka 'Eagle Range', etc.
Here is the official Air Force statement about the trunking system: (In Part)
Description
Hill AFB has acquired a new state of the art trunking system that provides handheld, mobile and base station radio users radio coverage to over 30 thousand square miles including Hill AFB, the Utah Test and Training Range (UTTR, North and South) and Salt Lake City. This system also includes dispatcher centers consisting of Security Police, Fire Department, Hill Consolidated Command Post, Aircraft Directorate, Disaster Preparedness, Base Operations, UTTR Range Control, and soon 388th MOCC.
Operation
A trunked system uses repeater channels to create a communications path. Hill AFB’s system is a four site system having 25 repeater channels, 10 on HAFB, 5 at Grassy Mountain at Oasis, 5 at Cedar Mountain by Dugway Proving Ground, and 5 at Salt Lake City at the Federal Building.
OK, now that we have heard the official version, we need to understand these things:
1. The bandplan listed in RR (in my expert opinion) is not correct.
Base 406.5, Spacing 408, offset 12.5 ( Offsets are 380-759, not 12.5! )
2. Last time I checked, RR was missing one frequency
3. The lowest actual frequency is 406.5625, 19d hex, 413 dec.
4. The highest actual frequency is 410.3625, 2cd hex, 717 dec
5. The lowest possible freq (in dec) is 380. (Courtesy of RR member fmon Frank)
6. The highest possible freq (in dec is 759. (from fmon)
When you program your custom trunking table,
the low must be 413 or lower
the high must be 717 or higher
These are the correct frequencies that I have verified.
6227c1 HAFB Golf Course
DESCR=Type II NetWkd 116.3 Hz
v406.5625,19d,021,ffff,0 (Not listed in RR database)
v406.9625,1bd,041,ffff,0
v407.3625,1dd,061,ffff,0
v407.7625,1fd,081,ffff,0
v408.1625,21d,0a1,ffff,0
v408.5625,23d,0c1,ffff,0
av408.9625,25d,0e1,ffff,0
av409.3625,27d,101,ffff,0
v409.7625,29d,121,ffff,0
dv410.1625,2bd,141,ffff,0
6227c2 South Range Cedar Mtn
dv406.7625,1ad,031,ffff,0
v407.1625,1cd,051,ffff,0
v407.5625,1ed,071,ffff,0
v407.9625,20d,091,ffff,0
v408.3625,22d,0b1,ffff,0
6227c3 North Range Grassy Mtn
v408.7625,24d,0d1,ffff,0
av409.1625,26d,0f1,ffff,0
av409.5625,28d,111,ffff,0
av409.9625,2ad,131,ffff,0
dv410.3625,2cd,151,ffff,0
6227c4 SL Federal Building
av407.5625,1ed,071,ffff,0
av407.9625,20d,091,ffff,0
dv408.3625,22d,0b1,ffff,0
Base, Offset, and Step: How they work.
There is an article by freq of nature about Base Offset & Step. I need to get with him and help write
a new article with correct information (when I get time) Until then, I will try to present the info here.
Examples of incorrect info: "Channel number 17C hex (=380 decimal) is the base frequency"
"Channels are numbered sequentially upwards and the step between each channel in kHz is the offset."
Base Offset & Step are parts of an algebraic formula used to calculate the frequency in Motorola VHF/UHF.
Take any two frequencies and their dec numbers:
407.9625 = 20d = 525. (This freq has 525 'steps' of 12.5 kHz)
408.3625 = 22d = 557. (This freq has 557 'steps' of 12.5 kHz)
To determine the Base and Offset, I first subtract to determine an "Offset Frequency" (My terminology)
407.9625 - (525 x .0125 MHz) = 401.400. (If the step is correct, both offset freqs will be the same)
408.3625 - (557 x .0125 MHz) = 401.400. (If the step is not correct, both offset freqs will be different)
Now don't get confused !! It is simpler to calculate using MHz: 12.5 kHz = .0125 MHz.
Now to determine Base, take the Offset Frequency and add, using the lowest possible Offset which is 380:
401.400 + (380 steps of 12.5 kHz): 401.4 + (380 x .0125 MHz) = 406.15.
So, now we have:
Base: 406.15, Offset: 380, Step: 12.5 kHz. Low freq: 413 or less (I use 380) High freq: 717 or greater.
And, for further confirmation, here is an old message from K7UHP when this TSYS first went digital:
Mon Sep 12, 2005 8:54 am RE: HAFB and PRO2096 Fixed
I programmed it using the software and it now works.
I had to use the multi table and selected
the low channel at 413, the high channel at 717,
Base of 406.1500, Offset 380 and Step 12.5 and it now works fine.
All Motorola VHF/UHF trunked frequencies are identified by a Hex/Dec number.
This is simply the number of Steps upward from an "Offset Frequency"
The Offset is simply the number of Steps downward from a Base frequency.
Base - (Offset x Step in MHz) = Offset Frequency.
Offset Frequency + (Dec x Step in MHz) = Operating Frequency
theaton
Member N7VU
Moab, Utah
HAFB UHF Trunking.
Thanks for the excellent information. I added the one new frequency, the additional ACC designations, and the more specific site location data to the DB. I've gotten conflicting information on the spacing and offset, and my understanding is far from perfect. Currently we have Base 406.5000, Spacing 408, Offset 12.5. So you are proposing Base 406.1500, Spacing 12.5, Offset 380? Gary, can you comment on this?
-Tim
gldavis
KE7MQF
Bountiful, UT
Good information. I'm glad to finally know where the sites are. The only difference I see is the Base Freq. I punched in 406.15 and both my scanners, and Trunker seem to like it fine. Now if we could only get some help with the Talk Groups.
kf7yn
West Jordan, UT
Ditto, thanks for the info. Mike Smith and others figured this out years ago when HAFB went trunked, and we discussed it at a scanner club meeting. I had forgotten how to do it. It must be that geezer thing setting in!
N7YUO
Kearns, UT
Being employed there gives me an inside track on who's who and what's what.
I know almost all TGRPs at HAFB and UTTR. I have lost my information on the TGs
for the Air National Guard (ANG). In 2005, when they went to 12.5 kHz digital voice,
The ANG and Federal Protective Services were assigned new TGRPs.
Right now my daughter is on the new computer, so I am stuck on the old Windows95 machine.
There are no files on it to upload.
HAFB TGRPs can be classified, er, I better not use that word! ...Organized! like this:
Operational: TGRPs that are used for daily operations. Police, supply,
Situational: TGRPs that are only active if there is a situation: EMTs
Seasonal: TGRPs such as SNOW removal
Training: War Games, disaster preparedness
Itenerant: Visiting Squadrons, Air Shows, Russian Inspectors
kf7yn
West Jordan, UT
Here's what I have for ANG. My list goes back to to the start of 6227 site #4 in SLC, it very well could be outdated. Any corrections would be appreciated.
16000 ANG Fire/Crash
16016 ANG Security Police A
16032 ANG Security Police B
30096 ANG Security?
30144 ANG Fire/EMS
30240 ANG Lima Control
30256 ANG
30272 ANG Maint
30288 ANG
30336 ANG Fuel
30384 ANG
30400 ANG Control
N7YUO
Kearns, UT
When Wasatch Federal switched to 12.5 kHz & digital voice,
The users who were not digital voice were assigned new TGRPs
These included:
EG&G Logistics Contractor at HAFB,
Air National Guard went from 16XXX to Somewhere Else
Federal Protective Services has new TGRPs
