HP-2: Program TGID into the HomePatrol-2
hiegtx
Dallas, TX
Is it possible to type the TGID into the HomePatrol-2?
If you have the Exreme Upgrade, you can add that via the keypad. But if you do not have the Extreme, the only way to add a TGID or otherwise edit the system is in Sentinel; after which, you need to send the updated system to the scanner.
john43554
If you have the Exreme Upgrade, you can add that via the keypad. But if you do not have the Extreme, the only way to add a TGID or otherwise edit the system is in Sentinel; after which, you need to send the updated system to the scanner.I have the
john43554
I have the Upgrade. A while back I received some great help from tvengr. Tonight I think I finally have something setup correctly so I may not need to enter the codes by hand...
