cmccarter
is there an app that can monitor and tell me what talkgrps or frequiencies are being used snf the ones that are just blank?
Assuming it's a p25 control channel you can use pro69com with your scanner to see what talkgroups are currently active on a specific tower but that's about it. I don't think a program exist that can tell you what talkgroups are actually assigned to someone and which aren't. You know... Aside from a system admin.
Troy I think OP is asking is there a program that will decode the CC and tell you what talkgroups are assigned to the system if they are active or not. That info is not transmitted by the CC to answer the OP question as I understand it.
i apparently do not know enough to ask the correct question, I Thought a saw mention of some type program (not sure which scanner) that is capable of monitoring your scanner somehow then giving you a list of all tlkgrps/channels that did not have any traffic during the monitoring period.
This could be used to remove dead channels groups so you can cut the scan time. Maybe I dreamed it but i thought is was called Pro something.
I think the Pro95com was the original program I read about but will investigate both now. Being retired gives me plenty of time to tinker
