Programing a Maxtrac 888
ve3tej
London, Ontario
I am having trouble with type 2 systems, type 1 systems work perfect.
I have a D35MWA5GF6AK and having trouble recieving type 2 systems. The radio appears to only pick up random transmissions on all talkgroups.
The systems I have tried are smart zone and do not use splinter frequencies and all work in my mtsx 8000
Any assistance in the right direction would be greatly appreicated
jjflashcode
Try setting up a system for each zone you want to listen to with the propper control channels for each system, Not sure what you really want to do But, If your just listening, NOT TRANSMITTING, you should be able to hear everything, because your radio is not pinging the tower, you are not getting anything off that tower unless someone else is in that Zone at that time.
If your Radio does ping the Tower and you are not suppose to be on that system, your Radio can get Inhibited and then you would have an expesive PaperWeight
Good Luck
Frank
