Programing a XTS3000
SCES
I am novice as far as programming is concerned, but this CPS from MOT has me baffled. It is not like the KW build the template and upload, but I believe I got the hang of it. I am able to get the channels and zones set-up - which is by far the most I'll ever do.
I'm sure I did something wrong, but it seems that I am no longer receiving anything. Is there a way to "reset" the radio so that I could begin building the database again? I was trying to get the scan function to work, but it didn't seem to be working - so Im sure I checked something or did something that wasn't meant to be done for my conventional needs.
Also, when keying up - is there away to have the Chirp Tone emit?
SCES
I recently bought an XTS3000 offline, and after programming it in my CPS - It is stuck on the "Self Test" start up screen. ANy ideas or someone local to boston that can help.
W1KNE
Owner ScanNewEngland
New England
In another forum, you mentioned every time you key it up, you get a chirp. Contact the radio shop vendor of the system you are trying to transmit to with your radio for assistance.
