Programing an HP-1
safetyobc
South Arkansas
Hello,
I'm not in your area but you could easily program it yourself. It should have came preloaded with frequencies. Also you could use the free software from Uniden called Sentinal to update any channels that have changed.
bfpdb
Carlisle, Ar
I had one of these before and got rid of it because of the way it has to be programmed. Yes it has everything in it but I dont want to spend all my time deleteing everything it hears all I want is what is In Lonoke county. I would be happy to Pay someone to program it but I really hate to send it to Scanner Master for that.
Voyager
You could just enter your zip code with a range of 0 miles, or use the SW to copy your county (or city) to a Favorite List, and just scan that. Much easier to edit in the SW.
Also don't forget to set the Service Types for what you do (or do not) want to hear.
mass-man
trying to retire...
Parker Co., TX
+1 to Voyagers recommendations. I generally keep one of my HP1's on 0 miles range, and it only hears my local PD and the SO! I have never played with favorites...I just sorta manually edit with range, service type and a few avoid button pushes.
03msc
RF is RF
The Natural State
This is what I was going to say as well. I'm not sure that you do, but if you have all service types turned on then you will quite possibly hear a lot of things you don't care to so I echo Voyager here and say check the service types as well.
