BCD436HP: Programing DMR Trucking System
Jacob
Martinez, Ga
When programing a dmr trucking system into the BCD436HP is it necessary to enter a LCN, and if you do not know the LCN is there a wild card that you can plug in the slot and is there a particular order when programing the frequencies.
IAmSixNine
Dallas, TX
If the LCN is not in the correct order it will not Trunk properly. Yes they have to be in the correct LCN order.
There is an LCN finder option. But if its a small or slow system it may take a while.
Jacob
Martinez, Ga
Thank you, it will be slow because it a very large rural county. I will set the scanner up and let listen until I have everything.
