Programing ECADS for Live Oak, UC area
thinshavings
Pearland, Texas
I need to program my pro2051 for the Live Oak ECADS system and remember reading about how the frequencies need to be in a certain order in the scanner.
Any one know what the order is?
loumaag
Silent Key - Aug 2014
Katy, TX
Not that it matters much for this system (since they don't skip) but EDACS (like LTR) needs to in the proper LCN slot (depending on scanner) also. So for example if they used LCNs 1, 3, 5, 7, 9; you would have to configure the scanner that way. On the old bank scanners, that means leaving holes in the lineup on those LCNs skipped. (2, 4, 6, 8)
thinshavings
Pearland, Texas
Not sure I understand. Here are the freq. for that system:
01 851.32500 02 851.82500 03 852.58750 04 852.88750 05 853.11250 06 853.33750
07 853.56250 08 853.67500 09 853.78750 10 853.91250
So when I put them in the scanner I should leave a space between each one?
Also which ones are the control freq.? There were no red ore blue ones on RR. Or does it matter?
NC5267
San Antonio
put them in that order, do not skip and everything will work. also the control channel does not matter as long as you put the freq in correct order, but the control channel is lcn 1 851.325
I live in the area so if you have any questions on talkgroups let me know, the database is pretty much up to date now.
