Programing help with TK-2170
dargent222
I have a TK-2170 radio. MY fire dept. has 3 houses. What I want is to put the radio on one channel and have the radio alert to each house. We use only one frequency for dispatch. I have the tone set as two tone 1,2, and 3 . I would like to have the radio sit on this one frequency channel and alert to which ever house is paged.
How can I do this ? the radio will work if I have 3 channels one for each house but I only get paged if the channel is set to the correct house before the page. If someone can walk me through how to do this. I do have the KPG 101D program.
thanks for any help.
KK6ZTE
California
How are your tones set up? Same A-tone with different B/C/D tones? Or a total cluster like most?
I just did one yesterday for a medic supervisor that was set up with a common leading A-tone and three unique tones for himself and two units under him to be alerted during the day, and set up A-B, A-C, A-D on "2-tone 1" and then just the A-B for night time on "2-tone 2" on a separate channel.
KK6ZTE
California
To correct myself, it appears the 170s will only do a max of two (A-B/A-C) (no A-D). Sorry.
dargent222
All of our tones are different A tone and B tone. The encode is the same. Can you tell me where in the program software I should be looking to put in the tones? Or under call format do I make one tone for station 1 as AB and station 2 CD . in the software I go to edit then encode and then I see a list of 10 places to put info. I also see in same place for decode two tone 1, 2 and 3 Just trying to get to the correct info into the right area in the program software?
KK6ZTE
California
EDIT->2-tone->Decode 1/2/3 (likely 2-tone 1, but check your dispatch channel Optional Signaling option to verify).
Set 2 to C-D and set the tones as needed.
Encode is for transmitting tones (you don't want that one).
dargent222
so I will only get house one and house 2 in 2tone 1 ? or is there a way to get all three houses in 2 tone 1?
KK6ZTE
California
Just two houses. On other Kenwood models you could get 3, but this radio will only support two. I have one on the bench in front of me I tested on.
Is there an all-call tone (long tone?) set for your battalion?
dargent222
Sorry no all call. not that I know of. I will ask. ok This will work for the most part. Thanks for the info.
