programing help
tony86s
im a newbie and just got this toy
(BearTracker Warning System with 800 MHz TrunkTracker III )
i was wondering if i am able to program that into my unit
Mowat 41MOWT (Toronto) 141.30000 141.43500 142.11000 142.68000* 142.90500* 143.34000 143.64000 152.00000
if someone could help me on that please and thank you
Dubbin
Findlay Ohio
You will need to be a little be more clear as to which scanner you have. Whats the model number?
NWI_Scanner_Guy
Hammond, IN
If it's the BCT8, throw that thing as far from you as you can. I've had mine for 4 days now and still can't figure out the trunking side of it. I'm so frustrated with it all I want to do is pull my hair out :eek: :D (and throw it (the scanner, not my hair) out the window)
SSSG
tony86s
do you know how to program 141.30000 141.43500 142.11000 142.68000* 142.90500* 143.34000 143.64000 152.00000 that on the scanner
Dubbin
Findlay Ohio
SouthSideScannerGuy said:
Then see the post right above yours
:D :)
Thats not the answer...
Tony, I'm sure someone will step up and help you out, many people on this forum has the same radio.
NWI_Scanner_Guy
Hammond, IN
You're right, it's probably not the answer he was looking for. I was trying to be funny, but I guess that fell pretty flat.
I was just venting is all.
At least I'm not the only one out here with issues with the BCT8. The thing truly is a pain in the butt to figure out.
Hopefully Tony will have better luck that I have had.
SSSG
