Programing Kenwood TK3180
BenSkerker
Attleboro Ma
I was wondering if there is an easy ways to program the Kenwood Tk 3180 to the 512 that it holds. I currently have 250. But it wont let me add anymore.Is there a setting i need to change in the Software to program.
Alarmguy
Former Alarm Guy, turned Radio guy
Deep in the heart of Jersey
How many Zones/Groups are you using? It sounds like you are using only 1 Zone. In My licensed copy of KPG89D it shows 250 Channels in Zone 1 in a blank data file. I have my 2180 and 3180 setup with various Zones with as many channels in it as I need. You are limited to from what I can see 250 Channels with 1 Zone. If you want more you can add more zones ie Zone 2 would then have 250 channels, and that would pretty much max you out.
BenSkerker
Attleboro Ma
i moved some channels around to different zones so it would be organized by counties but they are not programming. Is there a certain thing i am suppose to change for the keys or something else
Alarms50
Ossining, NY
ramal121
Lots and lots of watts
Calif Whine Country
In the zone edit window, upper right, what do you have for "free area"? If it's zero or nearly so you cannot add any more channels.
BenSkerker
Attleboro Ma
I have plenty of room in the Free area It just wont let program the other zones to the radio.Also when a fire department comes up it shows up as a different department even though its programed as a certain one.
ramal121
Calif Whine Country
Jeez, don't really have a clue. Nothing in software to set maximum channels. You should be able to add to any zone until it all fills up. After that, an error message will pop up with something like "no memory left". Do you get any error message when adding channels or does it just not allow you to type into the boxes?
Also, what do you mean another department shows up. Is the radios channel/zone not following what is entered in the zone information window?
BenSkerker
Attleboro Ma
I am not getting any error message.It is letting me add other frequencies in other zones but then it wont program to the radio. I am not sure if i should change the key assignments around so they could be added but it not programing anything from the zone 2 at all. Also it comes up as department that is not transmitting and a department that is comes over as the department that is not talking at all.example is department a is dispatching a call and department b i doing nothing its coming up as the department b and they are not going any where.
