Programing Michigan's Public Safety Communications System (MPSCS) in my Scanner?
bud22923
For years I have been programming all frequencies for each tower on my banks.
I wanted to ask this question to all of you out there should I be programing all the frequencies for each tower or should I be programing just the Primary Control Channel and Alternet Control Channel to each of my banks?
smithken
Michigan
What make/model scanner? If it's a uniden scanner you just need to program the control channels and, if it's an older scanner like a BC296D, you need to set it to the right plan. If it's a Radio Shack, GRE or Whistler scanner I have no idea how to program those.
jaspence
Michigan
You probably will have problems due to the simulcast with a scanner that old. I have the Pro 18, Radio Shack's last digital scanner, and with the upgrade it is good in my area, but some systems using simulcast are difficult to monitor successfully.
smithken
Michigan
OP doesn't say where in the state they are located so simulcast may or may not be an issue, I don't see any simulcast north of the Bay City-Saginaw areas.
jaspence
Michigan
I am in Washtenaw County, about 25 miles from Detroit. Nothing but simulcast on the MPSCS.
iMONITOR
Silent Key
S.E. Michigan
Just the red primary and the blue alternates. If primary goes down it will go to the alternate automatically. Do not program all the voice channel/frequencies.
jaspence
Michigan
I was referring to the county level, not individual entities. In some parts of the state, smaller jurisdictions are still using FM on lower frequencies.
