Programing problem with BCD536HP
engineer69
Chicago IL
I can not get the radio to program using the butel software. I plug in the USB cable and the radio says USB Mass Storage and after that it will not detect the software. I know its not the program because I have a second radio that has no problem. Am I missing a setting on the radio itself. I dont know
caldwest
Charleston, SC
I have the same problem. A couple of days ago I was able to get the Butel virtual control software to work by changing the baud rate to 128,000. I thought things were fine until a few minutes ago when I tried to download from the scanner. I got the same message that you did saying that the scanner can't be detected.
Sam
caldwest
Charleston, SC
engineer 69,
I just fixed my problem. described above
I did not realize that two drivers are required: one for the serial port and one for mass storage. I just loaded the mass storage driver and the program is working as advertised. Do you have both drivers installed?
Sam
fxdscon
¯\_(ツ)_/¯
engineer 69,
Sam
There are no mass storage drivers provided by Uniden, nor are there any needed, to use either of the x36 scanners in Mass Storage mode.
http://forums.radioreference.com/un...0094-436-usb-cable-connectng.html#post2181392
Your computer should recognize the scanner on it's own, as it would any other mass storage device.
caldwest
Charleston, SC
fxdscon,
When I tried to use the mass storage, I would received a "Code 10" error.
I could not get mass storage to work until I clicked on the Uniden port under devices (it had a yellow triangle to flag the problem). I selected update drivers, select from the computer, and was given a screen to select either serial port or mass storage. I selected mass storage and the driver loaded on its own. Now mass storage and virtual control are both working for me for the first time.
I just checked the driver update again and all that is there now is Uniden Serial Port.
Whatever hoops my computer had to jump through, the above worked for me.
Sam
