stephen123456
I am try to program my scanner for my town dpw and I am,having issues. Any help will,be appreciated
Radio shack scanner 651. Town of henrietta ny
Thank you Mike. Do you have a recommendation for what type of scannerr I shound get for my areaUnfortunately the 651 will only partially work in your area. According to our database
Monroe County, New York (NY) Scanner Frequencies and Radio Frequency Reference
Scanner Frequencies and Radio Frequency Reference for Monroe County, New York (NY)www.radioreference.com
Monroe county uses a trunked system that is partially type 2, which your scanner can't decode. Only those talkgroups marked 'D' in the Mode column would be receivable.
In addition, your town's DPW uses DMR, which is yet another mode that scanner can't handle.
There are quite a number of scanners that can now handle DMR and Motorola Phase II - the list can be found here under 'Scanner Support for TDMA'...
APCO Project 25 - The RadioReference Wiki
wiki.radioreference.com
However if you still want to learn how to use this scanner, this article has numerous links to help you along, including user guides for ARC500 and Win500...
Getting Started with your GRE/RS Object Oriented Scanner - The RadioReference Wiki
Mike.
