What scanner are you using? Where are you located? What tower or towers did you program into your scanner? Did you manually program it or use software?
So im located in hardin county, i have a ws1080 and i basically auto loaded the whole setrrs into it and it works fine, but when i wanted to put the challenge yo myself and try to program my kinda thing to make it work the same because I was bored it wasnt working, and i used the vidor orange county towers and the orange orange countytowers and the port arthur jefferson towers, and ince again I have setrrs in the scanner but i wanted to challenge myself and it doesnt pick up those the same
Just program in the Jefferson County Simulcast tower. That is all I have programmed into my sds200 and it pickups everything on SETRRS, all of Hardin, Jefferson, and Orange counties. Then avoid any TGIDs you don't want to listen too.
Depending on your antenna you may be too far away to receive the other towers.
