ProGrammer Help
patrick911
Canada
Hi everyone
I'm new with programming ma/com radios and would like to know were to put my talk group id in the software. I have version R17A05
Thank you
Pat
patrick911
Canada
Hi again
But were do I put the id (02-127) Because in group id I cannot put any slash. Is it because it's in DEC format only?
Thanks for your help
Pat
patrick911
Canada
While i'm here is it possible to program on 1 radio both Provoice and analog at the same time
thank you
Pat
wiliki46
Yes, you can do analog and Provoice at the same time. Make sure for each talk group you set the voice mode for analog or unencrypted. Also under the system setup you select Provoice as the vocoder.
patrick911
Canada
Ok I have one more question for you guys
How can I programm the radio so when i'm far from system1 but close to system2 that he can activate himself system 2 and deactivate sytem1
Thank you
Pat
wiliki46
Just turn on the system scan. Under the system menu go to the EDACS tab and fill out the bottom. The radio will choose the strongest system it is receiving. So on the fringe areas the radio will jump between systems. Hopefully your radio has Proscan. Read through the felp files. It will explain things better.
