programming a 2180 in trunked
njffemt08
Was emtfirebug14
hey yall ive programmed my 2180 in conventional mode currently. i am needed to know update it and put it in trunked. when programming as trunked does it matter if only certain channels are now being placed on a trunked system?
ramal121
Lots and lots of watts
Calif Whine Country
Well you would build your system correctly and have all the repeaters in their right spots. Then you can add GIDs as you wish, depending who you want to yak at. Not sure exactly what you're asking.
njffemt08
Was emtfirebug14
My question is. Is there any issues when certain channels need to be programmed as trunked while others are still conventional
ramal121
Calif Whine Country
Trunked systems and conventional channels need to be in separate zones, but should not cause any issues using one or the other.
The only thing I can think of is trunking will slow down your scan speed quite a bit.
