SteveC0625
Order of the Golden Dino since 1972
I just received a used CDM750 VHF, and am having some problems programming the P1 and P2 programmable buttons.
Our primary channel has a repeater at the north end of the county, but operates simplex on the output side of the repeater for the central, western, and southern areas of the county. I entered the proper frequencies and TPL codes and the radio hits the repeater just fine.
I want P1 Short Press to toggle the Talkaround feature, and set it to do that in the Programmable Buttons menu. I also checked the Talkaround box in the proper personality menu.
The software writes to the radio properly, but when I replace the programming cable with the microphone, pressing the P1 button just gets a single beep and no change in the repeater access. It if works correctly, I think I should get an indicator light above the P1 button, and the tone should be a beep-beep indicating in or out of Talkaround.
I tried programming P2 for Talkaround and got the same results. Can't seem to get Hi/Low Power to work, either. I also tried to set one of the channels to a lower power setting and that won't take either.
What am I missing?
What am I missing?
