Programming a type 2i hybrid on a bc246t
sunfireguy
Is it possible to program a motorola tye lli hybrid system on a bc246t, if so how do i do it with arc246
Forts
Ontario, Canada
Yes you can do that no problem. In Arc246 it would be under the system properties tab I believe where you would enter the fleetmap info. If it's a new system you are trying to map out it may take a little tinkering to find the right size code for each bank. If the fleetmap is already listed here on RR then you can just enter it as is.
