Programming a VHF M-RK
swcscott
ohio
When programming a VHF M-RK ( 136 - 160 ) for bandwidth do I select narrow or wide? I can't get either to work. All voice traffic sounds distorted and pulsating. I don't know if I have a setting wrong or if there is something wrong with the radio. Any help would be greatly appreciated.
Thanks.
flecom
Miami, FL
you should select whatever bandwith that channel uses... wide for 25khz and narrow for 12.5khz
if you program them all as wide and you hear a channel really quiet then chances are its a 12.5khz channel...
not sure why its "pulsating"... does it do this even at low volumes? if so you might have found a "birdie" on the radio, try changing the oscillator shift... if that dosent do it you might have a tracking data issue, bad speaker or something wonky on the logic board...
