programming abbreviations in scanner
Colton25
So i have seen in fire trucks on their radios each channel has a name/abbreviation for the frequency so they can easily know what frequency they are on or using.For example it will say TUU L. They easily know what frequency they are using instead of just seeing numbers. My question is can you program scanners with abbreviations??? Instead of seeing 151.1900 it would say TUU L. Please help if anyone knows the answer!!!
Thanks, Zane
nc28478
nc28478
Wirelessly posted (indulge: Opera/9.80 (X11; Linux zbov; U; en) Presto/2.10.254 Version/12.00)
what scanner do you have?
always provide as much info as you can so the experts of RR can help.
I have learned so much from RR!
now I will step aside, so the expert'in can procede...lol
nc28478
nc28478
also you are referring to
"alpha tags"
KB7MIB
Peoria, AZ.
Wirelessly posted (Mozilla/5.0 (X11; Linux i686; U; en-US) Gecko/20081217 Vision-Browser/8.1 301x200 LG VN530)
It depends on the make/model of scanner. Several do have alpha tag capability, such as the newer digital scanners, but not all.
nc28478
nc28478
See, it's best to leave the expert'in to the professionals...lol
KB7MIB
Peoria, AZ.
LOL I am so not an expert. I know a little about a lot. Just enough to get me into trouble :D
W2NJS
Washington DC
Zane,
You probably got an instruction manual with your scanner and that will tell you what the radio will and will not do. If you don't have the manual you can probably find it online with a Google search.
Colton25
I did some research and found that the scanner i have, BC355C does not and i found that the BCT15X would be great for alpha tagging.
