Programming BC898T for Fleetnet
bigcam406
oshawa,ont,canada
I want to program Fleetnet into this scanner.the instructions say I must use the Motorola E2-high mode.(which is Motorola vhf ).what im wondering before I start,is ,after reading the stickies provided in this forum pertaining to Fleetnet,they don't mention the 898t,only the digital models and the analogue 246.will these same instructions apply?ive used these stickies before for programming my GRE500 to great success,so if anyone can chime in,its appreciated.also,im wondering when entering freq's,do I enter all or just control channels.thanks again.
davidmc36
South East Ontario
The WIKI does not say Control Channel Only trunking so you would need all the channels.
I think the programming should be pretty straightforward if you start at Page 41
The programming will be fairly different from the 246 and other DMA scanners. It will be more like a 796 or something (with banks).
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Looks similar to the 396T/996T. Once you enter the base, offset, step and control channels, you should be set.
Since it's using base, offset and step to calculate frequencies, you can probably use Control Channel Only mode if it has it.
If you find your not hearing anything and the scanner is stopping on the control channel, than you can turn it off and enter in all the voice channels.
davidmc36
South East Ontario
Uuuuuh, not a good comparison really, more like 796 with banks, not DMA, except no digital, analog only. (You will not get OPP or MTO Enforcement.)
No CC Only mode on the 898, so it needs all the channels.
It's a Big Brother to the 895 with more channels, TG ID's and trunk types (basically added EDACS and LTR).
hawkeye32
Windsor
Uuuuuh, not a good comparison really, more like 796 with banks, not DMA, except no digital, analog only. (You will not get OPP or MTO Enforcement.)No CC Only mode on the 898, so it needs all the channels.
I have the 898T, you can get away with just the CC and tyhe alternate. No need to put in all the freq's unless you really want too.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
I was referring to the fact that programming a VHF trunking system was similar to the 396T/996T.
Keep in mind that on newer Uniden scanners, you can't select Control Channel Mode either. Uniden has decided that everybody should be using Control Channel Only mode and the option to turn it on or off is gone.
bigcam406
oshawa,ont,canada
i programmed Fleetnet into my 898t this afternoon,and i just entered the control channels with the local tg's.i didnt receive anything ,so i then entered in the voice freq's and it worked.thanks for the help guys.
